ICQ: 151516 Репутация: 209
Storm 2008
![]() ![]() Storm 2008 - это скромный icq бот, преимущественно для тех, кто занимается брутом на выделенных серверах. Он предназначен для облегчения управления брутом и его автоматизации. Работает совместно только с IPDbrute 2 Pro SE. Возможности:
Список команд : Код:
IPDbrute control: /ipd (or 1) - show IPDbrute statistics /start - press 'start' button in IPDbrute /stop - press 'stop' button in IPDbrute /cleanup - press 'cleanup' button in IPDbrute /show - show IPDbrute and bot windows /hide - hide IPDbrute and bot windows /runipd - run and start IPDbrute /killipd - hard terminate brute process /good - show good list Bot administration: /adminlist - show admin list with permissions /add - add UIN to admin list syntax: /add UIN[:permissions] ex.: '/add 123123', '/add 321321:+-+-' permissions: 1 - send new good's, 2 - allow to use commands, 3 - allow to use /ipd, 4 - allow to administrate bot default permissions is -+++ /delete - delete UIN from admin list syntax: /delete UIN; /pchange - change permissions syntax: /pchange UIN:perm_index:permission , /pchange UIN:permissions ex.: '/pchange 123123:1:+', '/pchange 321321:+-+-' /settings - display bot settings /set - set bot settings syntax: /set -option value note: for information send '/set ?' /botlog - show bot log syntax: /botlog [count] default count is 10 note: large messages will not be delivered /messlog - show messages log syntax: /messlog [count] default count is 10 note: large messages will not be delivered /pluglist - show list of plugins Source lists managment: /srclist - show queued source files /srcadd - add source list to queue syntax: /srcadd file ex.: '/srcadd C:\file.txt', '/srcadd my.txt' /srcdel - delete source file syntax: /srcdel index /srcup - move up source file in queue syntax: /srcup index /srcdw - move down source file in queue syntax: /srcdw index /schange - change current source file syntax: /schange [proxy_update_type], /schange 1[:url] ex.: /schange 2', '/schange 1:http://site.com/list.txt', '/pupdate 1' proxy update types is: 1 - download from url in settings, 2 - update from local copy, 3 - do not update. /gen - generate new source list syntax: /gen uinlists|passlists[+], /gen uinlists:passwords[+] ex.: '/gen uins.txt|passlist.txt,simple.txt', '/gen 6xy.txt,7xy.txt,8xy.txt:test,123+' note: '+' - auto add this list to queue /gen+ - analogue command /gen with the removal of duplicates (but slower) Proxylist managment: /proxylist - save new local copy of proxy list syntax: /proxylist list_of_host:port ex.: '/proxylist xxx.xxx.xxx.xxx:yyy xxx.xxx.xxx.xxx:yyy xxx.xxx.xxx.xxx:yyy' note: the count of symbols in message is limited by protocol /pupdate - update proxy list in brute syntax: /pupdate [proxy_update_type], /pupdate 1[:url] ex.: '/pupdate 2', '/pupdate 1:http://site.com/list.txt', '/pupdate 1' /cleanupex - cleanup proxies wich have avg_connect_time_sess value bigger then specified syntax: /cleanupex [max_avg_connect_time_sess] note: if max_avg_connect_time_sess not specified then using default value in bot settings Misc.: /cmd - open command line note: send 'exit' to close cmd /closecmd - close command line note: this closing method can be used when cmd is opened by another number /get - download file from url syntax: /get url ex.: '/get http://site.com/file.txt' /gate - open icq gate with other UIN syntax: /gate UIN /closegate - close current icq gate Storm 2008 Brutal Edition ![]() ![]() Storm 2008 Brutal Edition - это аналог оригинального бота Storm 2008, предназначенный для работы с .Brutal. Как и оригинальный вариант, он предназначен для облегчения управления брутом и его автоматизации. Возможности:
Поддерживаемые версии Brutal: от 0.3 до 0.8+. Список команд : Код:
.Brutal control: /stats (or 1) - show .Brutal statistics /start - press ’start’ button in .Brutal /stop - press ’stop’ button in .Brutal /pause - press ‘pause’ button in .Brutal /continue - press ‘continue’ button in .Brutal /cleanup - clean proxies in .Brutal syntax: /cleanup [proxy_type] proxy types: https (h), socks4 (s4), socks5 (s5) note: without parameter = cleanup all proxies /brtopt - display .Brutal options /threads - set threads count syntax: /threads value /timeout - set timeout option syntax: /timeout value1 value2 note: value2 used only with .Brutal 0.5 /clntime - set cleanup time syntax: /clntime value /autosave - set autosave time syntax: /autosave value /show - show .Brutal and bot windows /hide - hide .Brutal and bot windows /runbrt - run and start .Brutal /killbrt - hard terminate brute process /good - show good list Bot administration: /adminlist - show admin list with permissions /add - add UIN to admin list syntax: /add UIN[:permissions] ex.: ‘/add 123123’, ‘/add 321321:+-+--’ permissions: 1 - send new good’s, 2 - allow to use commands, 3 - allow to use /stats, 4 - allow to administrate bot, 5 - notify terminating default permissions is -+++- /delete - delete UIN from admin list syntax: /delete UIN /pchange - change permissions syntax: /pchange UIN:perm_index:permission , /pchange UIN:permissions ex.: ‘/pchange 123123:1:+’, ‘/pchange 321321:+-+-+’ /settings - display bot settings /set - set bot settings syntax: /set -option value note: for information send ‘/set ?’ /botlog - show bot log syntax: /botlog [count] default count is 10 note: large messages will not be delivered /messlog - show messages log syntax: /messlog [count] default count is 10 note: large messages will not be delivered /pluglist - show list of plugins /clrlog - clean system and messages logs Source lists managment: /srclist - show queued source files /srcadd - add source list to bot queue syntax: /srcadd file ex.: ‘/srcadd C:\file.txt’, ‘/srcadd my.txt’ /srcdel - delete source list from bot queue syntax: /srcdel index /gen - generate new source list syntax: /gen uinlists|passlists[+], /gen uinlists:passwords[+] ex.: ‘/gen uins.txt|passlist.txt,simple.txt’, ‘/gen 6xy.txt,7xy.txt,8xy.txt:test,123+’ note: ‘+’ - auto add this list to queue /gen+ - analogue command /gen with the removal of duplicates (but slower) Proxylist managment: /https - save new local copy of https proxy list syntax: /proxylist list_of_host:port ex.: ‘/proxylist xxx.xxx.xxx.xxx:yyy xxx.xxx.xxx.xxx:yyy xxx.xxx.xxx.xxx:yyy’ note: the count of symbols in message is limited by protocol /socks4 - save new local copy of socks4 proxy list (is the same as previous) /socks5 - save new local copy of socks5 proxy list (is the same as previous) /upd - update proxy list in brute syntax: /upd [proxy_types] [proxy_update_type] [/mode] ex.: ‘/upd h,s4’, ‘/upd s4,s5 2’, ‘/upd a 1’ proxy types: https (h), socks4 (s4), socks5 (s5), all (a) proxy update types: 1 - download from url in settings, 2 - update from local copy proxy update modes: /a - add new list, /r - replace by new list Misc.: /cmd - open command line note: send ‘exit’ to close cmd /closecmd - close command line note: this closing method can be used when cmd is opened by another number /get - download file from url syntax: /get url ex.: ‘/get http://site.com/file.txt’ /gate - open icq gate with other UIN syntax: /gate UIN /closegate - close current icq gate Вкратце описывая его преимущества, можно отметить, что он предоставляет широкие возможности по управлению процессом брута, т.к. делает всю ручную работу за вас. Обновление прокси, организация списков для брута и отправка новых номеров прямо вам в icq позволит вам экономить время и траффик, и в то же время быть в курсе событий происходящих на сервере. Скрытие окна брута (в том числе и своего) и иконки в трее (в Brutal Edition) даст вам шанс избежать того, что вашу учётку могут заблокировать, потому что, админ, зайдя в вашу учётку никаких окон не обнаружит ;) Управление командной строкой при помощи бота даёт полный доступ к серверу, что по сути является очень удобным, т.к. с помощью неё можно делать практически всё: управлять файлами, учётными записями, перезагружать сервер, работать с консольными приложениями (в частности консольные rar и zip) и многое многое другое. Встроенный генератор позволяет создавать списки uin;pass прямо через бота, используя списки номеров, списки паролей или пароли, передаваемые в параметр команды. Таким образом, вы можете создать несколько списков и долгое время не заходить на сервер, в то время как бот сам будет менять списки, обновлять прокси и присылать вам новые номера. Присутствует так же возможность восстановления процесса брута после разрыва связи с интернетом. Бот делает резервную копию списков прокси после разрыва, а когда связь снова появляется, он восстанавливает все прокси и запускает брут, потому не нужно будет больше беспокоится о бесполезных простоях сервера. Что бы не перегружать бота не всегда нужными возможностями, и в тоже время расширить его функционал, существует расширяемая система плагинов, а так же SDK для разработки собственных. Более подробное описание, руководство по использованию, плагины и прочее можно найти на домашних страницах ботов: для Storm 2008 и для Storm 2008 BE Скачать Storm 2008 Скачать Storm 2008 BE Последний раз редактировалось q1p; 27.09.2009 в 01:29. |
#29 | |
ICQ: 313377 Репутация: 32
кароче я посмотрел, когда он ловит гуд, файл good.txt занят процессом Storm~ Добавлено через 1 час 18 минут ы.. запретил Stormu любые операции с файлом good.txt +) все пашет Последний раз редактировалось ScRatch; 01.10.2008 в 01:37. Причина: Добавлено сообщение |
#30 | |
отличный софт! xp&2k3 Последний раз редактировалось SVErY; 01.10.2008 в 17:43. |
#34 | |
проблема товарища ScRatch была решена, обработка гудов теперь реализована более корректно, и не должна вызывать проблем на винтах старого поколения
ещё чуть доработал принцип команды /stop, теперь бот оповещает когда брут остановлен, например: Цитата:
кстати, файл по ссылке иногда обновляется по причинам мелких доработок и исправлений. дату билда бота можно посмотреть в About или при помощи недокументированной команды /info, при чём последняя ещё показывает некоторую полезную инфу о сервере :) Добавлено через 21 час 18 минут добавлена поддержка Brutal версии 0.4
. Последний раз редактировалось q1p; 05.10.2008 в 23:02. Причина: Добавлено сообщение |
#35 |
очередной свежий билд под свежую версию брутала
на самом деле он был уже давно готов, на блоге выложил сразу же, просто только сейчас добрался до форума
линк как всегда тот же
. Последний раз редактировалось q1p; 23.04.2009 в 01:20. |
#36 |
и снова обновление:
#39 |
ICQ: 868699 Репутация: 522
#40 |
ICQ: 405605 Репутация: 989
У меня одного Storm 2008 (IPD) перестал отвечать на команды?
Добавлено через 31 минуту Неужели его никто не юзает?) Последний раз редактировалось ChessMaN; 29.05.2009 в 23:36. Причина: Добавлено сообщение |
#42 |
Обновлён (27.07 21:31):
Так же включена поддержка будущих версий, в том случае, если их изменения не повлияют на совместимость. В противном случае будет выходить обновление, учитывающее изменения новых версий брута.
. Последний раз редактировалось q1p; 28.07.2009 в 02:26. |
#43 |
Припоздавшее обновление (26.09 00:00)
Примечание: если брут не запущен и в настройках бота правильно указан путь к исполняемому файлу .Brutal, а в его директории существует файл config.txt с именами файлов (которые появились начиная с .Brutal 0.8), то бот по умолчанию работает именно с этими файлами. Это следует учитывать, если вы работаете с более старой версией .Brutal; так, например, вызвав команду обновления прокси - обновлятся они будут в файлах, имена которых были взяты из настроек .Brutal (повторюсь - это только в том случае, если сам .Brutal в это время не запущен, т.к. если он запущен, то бот определит версию и решит с какими файлами нужно работать).
#45 |
LittLe, наверное нет
я сам брутом уже давно не занимаюсь, бота обновляю только потому, что ещё есть люди, которые им пользуются и было бы не хорошо с моей стороны его забросить, но только вот времени для этого всё меньше и меньше
#48 |
ICQ: 60806 Репутация: 625
можно ли сделать в плагине к хантеру чтобы он его включал автоматом,допустим каждый час,хант сканил диапазон на определенный порт а затем после окончания скана добавлял (а не заменял) прокс в бруте? (юзаю брутал).
возможно ли так автоматизировать процесс? Добавлено через 12 часов 28 минут что никто не знает чтоли?никто уже не юзает шторм?) подскажите кто знает плиз Последний раз редактировалось tukes; 09.04.2010 в 14:27. Причина: Добавлено сообщение |
brute, icq., soft |
